I have a vibration I looked for the wieght on the flexplate seen during install not after it is a pioneer heavy duty 184 tooth jegs special flywheel on my C6 390 looks like it does not seat right transmission shop said sounds like I installed bacwards .
1 the weight should be facing engine
2 the dished taperd part of the flex should face the engine
3 small vibration and I had to shim my starter or it rubbed on the teeth of the flexplate .
did I screw up and put my flexplate on backwards ??
- Ranchero50
Re: did I screw up and put my flexplate on backwards ??
Should it have a weight?
If you flip the flexplate where does the drain go?
I took the pic to the shop that rebuilt the trans he said it looked right in the pic I turned it 360 I seen no wieght at all only thing I can think is stick something on like heavy magnet give it a few blips to 2,500 see if it smooths out and Mark each place I put it with chalk till.i find the sweet spot ..other wise me do it take 3 weekends or take it to him and pay 400 that's 125 per weekend .....
I wouldn't experiment with that , you might wear the bearing out prematurely.SoCal250 wrote:only thing I can think is stick something on like heavy magnet give it a few blips to 2,500 see if it smooths out and Mark each place I put it with chalk till.i find the sweet spot ..
Can you look at a known stock flywheel and determine if and where the weight is ,even a picture?
Being a new part it is possible someone screwed up.
I was told to use the same number of teeth that was originally if you don't you can have starter problems. Hope this helps.
I ran a 390 years ago and im fairly certain the 360/390 engines were neutral balance without a weight on the flexplate. I think the only Fe engines that were externally balanced were the 410 and 428 engines. Someone correct me if im wrong.
1969 ford f100 351w aod
1967 f250 4x4 351c m50d
- sargentrs
rabbithunter2005 wrote:.....im fairly certain the 360/390 engines were neutral balance without a weight on the flexplate. I think the only Fe engines that were externally balanced were the 410 and 428 engines.....
