Stupid question of the day. I put in a rebuilt in my truck last October, and am in the process of disassembling the old engine. I removed the cam thrust plate on the front of the block, but the camshaft won't pull out. I applied a little pressure with a prybar, but it only seemed to bind the camshaft to where it couldn't turn. With the rebuild, I just slid the new crankshaft in, and put on the thrust plate on the front. What am I missing? Do some blocks use a retention bolt at the rear, under that end plate?
Joseph
Need Help Removing Camshaft
- colnago
Re: Need Help Removing Camshaft
Should pull right out, maybe some varnish on the unworn area of the bearings.
1967 F-100 4x4 custom cab.
- basketcase0302
Make sure you have all the lifters out of their bore, (not binding on a lobe) and it should slide out.
I'd used a "body hammer" type puller before to get past the varnish lip that busboy described before.
- Ranchero50
Lifters out as well as the distributor...
Then use a long water pump bolt as a handle to remove it.
- colnago
Well, I got it. It just needed a little encouragement. I just needed to make sure I wasn't prying on something that I shouldn't.
Thanks!
Joseph
Thanks!
Joseph
