Stock dash speaker?
cdnwillyg
Stock dash speaker?
Post by cdnwillyg »
I am at a loss as to how the under dash speaker is suppose to be installed. :hmm: I didn't take the speaker out so not sure what if anything is missing or am I just not seeing it and I don't have it so can't even try it to see. A pic would be nice and a size, thinking 5x8 is what I think I read. :? I have two working original radios so would like to put this back to stock with a speaker similar.
Thanks
Stony Plain, Alberta, Canada
:drive:Willy
Bill Ramsey
Re: Stock dash speaker?
Post by Bill Ramsey »
if i remember correcty, there is a bracket that the speaker fits into. then the bracket goes into a slot under the dash, and a bolt other end. I saw one of the brackets sitting in the bed of one of my parts trucks yesterday.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
cdnwillyg
Post by cdnwillyg »
Any chance of a pic of this bracket to see if I have one ?
:drive:Willy
Ohiotinkerer
Post by Ohiotinkerer »
1997 Honda CBR 900RR
Bill Ramsey
yeah that's it. the og speaker has a square magnet that fits in the square bracket hole.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
cdnwillyg
Post by cdnwillyg »
Thanks both of you, and yes I don't have it but then with a new speaker it wouldn't have worked anyhow. I will now try and fab something up but have a question. You said that the magnet went thru the square hole, is it okay that the magnet touches the holding bracket?
:drive:Willy
IIRC the stock speaker magnet is a sort of square roll not typical of current speaker magnets.
I would try to fabricate something that held it by the basket is possible.
LMC and probably others sell a set up that puts 2 Smaller speakers in a special bracket...
cdnwillyg
Post by cdnwillyg »
Robert I went and look at LMC and can not find the speaker bracket you said they have? No luck in finding others either. :hmm: It would be really easy to modify an original to work if I had one. Anyone have an extra one they would sell? :D
:drive:Willy
jzjames
Post by jzjames »
I wanted the dash speaker in its original location and when I changed my dash pad I just bought a speaker of similar size to the original
and then I was able to just use 4 zip ties through the 4 holes of the speaker and looped through the 4 holes in the dash.
Worked for me and the dash speaker sounds good too.
cdnwillyg
Post by cdnwillyg »
Good solution if I had my dash pad off, not wanting to take it off after the pain of getting it on so it fit right.
I went thru my parts again and I found the bracket...not sure how I missed that the other 3-4 times??? :? My eyes must be playing tricks on me as this is not the only thing I have found...after I bought ANOTHER. :lol:
So now the speaker can't fit because its not stock, and I don't think there is enough room to make a bracket that will work with out interfering with the radio. :cry:
:drive:Willy
Bill Ramsey
I used the bracket to mount 2 4" speakers. I can't remember what I did, I just know the sound sucked.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
cdnwillyg
Post by cdnwillyg »
Well I made a speaker bracket to fit my 6x9 in the same config as the original. :D
It went in like it was meant to but......... :eek:
the speaker is deeper than the original by 1/2" I guess because the radio would not go in. :cry:
So now I need to find a 6x9 speaker that is 2.5" deep. :doh:
:drive:Willy
