Rhino Liner
Tallboy
Rhino Liner
Post by Tallboy »
Thinking about having rhino sprayed in the cab, under the cab, on the firewall, and in the bed. Pretty much encapsulating the cab and bed.....
Primered first then sprayed in. What do you all think of this idear?
72 F250 4x4 Ford GT Red.
FE 428 Trust me it goes....
heep70
Post by heep70 »
Good idea if you got the cash. Make sure you use a sealer/etch primer. That stuff won't stick on smooth metal.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
jor
re: Rhino Liner
Post by jor »
I used the Herculiner product from AutoZone and did my cab floor, firewall and front fenders as well as the bed. Seems to be holding well after a couple of years.
jor
Sharkdance
re: Rhino Liner
Post by Sharkdance »
I agree with jor. Herculiner works well.
I just did mine last week or so:
http://www.fordification.com/forum/download.php?id=2818
http://www.fordification.com/forum/download.php?id=2822
http://www.fordification.com/forum/download.php?id=2823
I did it because I like the look. Now Im thinking about the benefits like heat and noise insulation.
Me thinks its a great idea.
Sharkdance
70 F250 2WD 360/C6
binder56jd
re: Rhino Liner
Post by binder56jd »
while working in amarillo,tx this past summer(05) i saw a late 80's/early 90's Ford F250 done completely in herculiner- the guy had rollered it on- did a good job- wished i'd had my camera!- jd
now serving #235
460 crew
re: Rhino Liner
Post by 460 crew »
I had sprayed mine on and used a product called hippoliner.
Tallboy
re: Rhino Liner
Post by Tallboy »
460 that looks really nice....
I want durable and rust proof for the next 35 years so Im gonna do the fire wall, undercab and inside of the cab. then the bed inside and bottom.
I think this will get me what I need and give me some good sound deadening.
3 weeks it goes into the sand blasters......
460 crew
re: Rhino Liner
Post by 460 crew »
Very nice, keep us posted with lots of pics like always. :wink:
Redcap
re: Rhino Liner
Post by Redcap »
I plan on doing the very same thing this summer to at least the cab floors, undercab and firewall...possibly the entire truck, inside and out.
binder56jd
re: Rhino Liner
when doing a coat job try to do it with the least amount of relative humidity possible- you can seal in moisture- which will then turn to rust on down the road- i met a body man in the NE that clued me into this-when they were selling the aftermarket undercoatings several years ago (mid 70's and 80's) they found ( in the 90's) that they had trapped moisture and the metal went ahead and rusted out under the coating- just a heads up- jd
now serving #235
Sharkdance
Re: re: Rhino Liner
Redcap wrote:I plan on doing the very same thing this summer to at least the cab floors, undercab and firewall...possibly the entire truck, inside and out.
I coated the inside of my firewall along with the floor and bottom. I had thought about doing the firewall outside but decided against it.
I like the look of a painted body color firewall.
Doing the underside and inside of the bed seems like I great idea to me too. Thats what I plan to do when I get around to prepping my existing bed for re-installation. But I dont believe that doing a whole truck would be cost effective or good for the truck.
That stuff dries hard as a rock! And like Keith said in another thread: "make sure you get every single nook and cranny. What you don't want is for an area that isn't covered to get wet and the moisture to start trying to work it's way up under the edge of the Herculiner coating. Since that stuff is so tough, you wouldn't know about the rust until it's ready to drop out completely."
Sharkdance
70 F250 2WD 360/C6
mrung0wa
re: Rhino Liner
Post by mrung0wa »
Jethro needs his bed bead blasted cause there's a shiite load of surface rust changing into the nasty unforgiving rust. Id love to do him up in that stuff!
Q: Realistically how much will I need to do it the right way one time...
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
Sharkdance
re: Rhino Liner
1 gallon will do the inside of an 8 foot bed. Then you need a little more to do the tailgate.
For the underside, your guess is as good as mine. But Im guessing a gallon.
Sharkdance
70 F250 2WD 360/C6
mrung0wa
re: Rhino Liner
Post by mrung0wa »
I changed belt buckles recently.
My new one makes my rust belt much lighter! :P
Lawrence 8)
