Fuel line routing'68
cdnwillyg
Post by cdnwillyg »
Does anyone have a pic of their fuel line how it is run from the frame over the A-arms to fuel pump on a 390? I looked at the diagram in tech section but not really clear on how it is run.
Thanks
Stony Plain, Alberta, Canada
:drive:Willy
cdnwillyg
Re: Fuel line routing'68
Post by cdnwillyg »
Well I couldn't wait so I went ahead and ran it with 3/8" tubing from near the fuel pump over the A-arm and around the steering box to the frame may not be original but seems to work okay.
:drive:Willy
