On my 67 240 I have decided to remove the Load-O-Matic distributor and install a conventional mechanical advance unit to match the non-Load-O-Matic carb. I noticed that the vacuum advance diaphragm on the new distributor has hose nipple instead of the compression fitting like the old one had.
Anybody have a pic of an original 240 that shows how the line/hose was configured? I would assume that the steel line from the carb just terminates to a rubber hose to connect to the distributor, but I'd like to be sure to keep it factory appearing.
Thanks!
Larry
1967/1968 Vacuum Advance Line
- Manny
Re: 1967/1968 Vacuum Advance Line
Metal line around the front of the engine to the distributor is best i see. Standard rubber hose termination. this is the best picture i found. Scroll right at half way down the page has a good dizzy side shot.
https://www.google.com/url?sa=i&rct=j&q ... 5723200242
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
