bent steel insert from water pump...
Carb
Post by Carb »
In my zeal to pop my distributor out I inadvertently put pressure on a steel insert going from the top of my water pump into the engine (the bent piece is on the engine side.Image
any advice on how to remove it? its pretty crumbly. Thanks?
Busboy
Re: bent steel insert from water pump...
Post by Busboy »
Small chisel, cut along the side of it and collapse it upon itself, then pull it out with dykes.... oops, I meant diagonal cutting pliers. :D
1967 F-100 4x4 custom cab.
colnago
Post by colnago »
I just got a replacement off of the bay. But I concur. Chisel to create a fold, then pliers or Chan-L-Locks to crimp and pull it.
Joseph
tnlprt
Post by tnlprt »
Screw a bolt in of the appropriate size
Grab on to the bolt with a pair of vise grips
take a hammer and hit the vice grips
Knocking the nipple out
