Dana 60
Dana 60
Wanted: Dana 60 rear differential 3:54 gears limited slip
- jimilivz
Re: Dana 60
You may want to include what spline count gear-set you are looking for. If it is 16 spline, as most of the 60's era Fords are, you may need to have new axles fabricated to accommodate the more readily available higher spline counts. Unless I'm wrong, no one makes new 16 spline, Dana 60 diffs anymore.
68 F250 CS Ranger 390 C6
Re: Dana 60
16 spline.
Thanks for the heads up
