Hello,
I'm new to the site and having some issues with my truck so I figured I would join the forum to see if anyone can give me some advice while I start working on my project. I recently picked up a 67 f100 with 352 v8. I just replaced the points, condenser and the coil, I went to fire it up and had a wire start smoking to the coil. I didn't mark the wires when I took them off so I know I hooked something up wrong, there is 4 wires but I'm not sure which side of the coil they go to. Any advice on how to hook them up properly or a wiring diagram would be greatly appreciated.
Thanks
Chris
Ignition coil wiring
- sargentrs
Re: Ignition coil wiring
Thanks for the reply. I think I have the wires in the right order, one of the wires I figured out was from an aftermarket tach so I just left that off for now. The other wire comes from where the coil is held down I'm not sure if that's a ballast resistor or not? But I hooked everything back up and can't get the truck to fire but I don't have anymore smoking wires. Are there any fuses or relays I should be checking as well?
- sargentrs
Have you checked your voltage at the solenoid and at the coil to determine if power is even getting to the coil? And you had a wire going from the coil mounting bracket to the coil? What's up with that?
