I took the 68 out on it's maiden voyage tonight after almost 3 years. I did replace the tranny pan gasket and had to refill it. I've put about 4 quarts of fluid in and the dipstick reads full. Yes, it was after about a 15 mile trip and at a good engine temp.
It shifts at very low rpms out of 1st and it is slipping as it goes into 3rd. When I had it running last I do remember the quick shift out of 1st, but not the slipping issue. My old tachometer is not installed. I can't figure out why it has 4 wires and the harness I installed only has one. I'm sure one is to the coil and one is a ground. Anyway, I can't tell you exactly what rpm's it's shifting at. I hope to pick up a new tach tomorrow or find installation manual on my old one online.
I thought I had seen an easy to read/use guide to adjusting the bands somewhere on here. I can't seem to find it anymore. Any help on either subject would be greatly appreciated.
Soon as I get it driving good, I can concentrate on the tech articles for the painless wiring harness install and the Mustang gas tank install.....
C4 band adjustment help, please
- 1968flareside
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
- 1968flareside
re: C4 band adjustment help, please
Just wondering if anyone has experience with this stuff from Lokar...
PN KD-20C4HT
and
PN SRK-4000
PN KD-20C4HT
and
PN SRK-4000
1999 F-150 XLT 4X4
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
- 1968flareside
The vaccum module on the tranny is suspect too. It has not been replaced prior to Sept. of 1996 and has been sitting since then, mostly. Could this effect the shifting?
1999 F-150 XLT 4X4
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
- 1968flareside
Ok. I installed a tach and haven't checked yet. I do know it is getting from 1st to 3rd before 30 mph and it is still doing the slipping/hesitating thing between 2nd and 3rd. If I shift it manually, it's fine. Fluid reads full when warmed up.
1999 F-150 XLT 4X4
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
- ToughOldFord
1968flareside wrote:Ok. I installed a tach and haven't checked yet. I do know it is getting from 1st to 3rd before 30 mph and it is still doing the slipping/hesitating thing between 2nd and 3rd. If I shift it manually, it's fine. Fluid reads full when warmed up.
That's exactly what my C-6 did with a bad modulator. That and a really hard 1st to 2ond shift. It was just all around better to shift it manually then.
Get a new modulator!
- 1968flareside
Re: re: C4 band adjustment help, please
Done. Here's an update...Jake11 wrote:Get a new modulator!
http://www.fordification.com/forum/viewtopic.php?t=9178
Need more help please!
1999 F-150 XLT 4X4
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
