I'm looking for ideas and materials of how to finish the rear of the cab after removing the gas tank and installing bucket seats.
I will probably build a panel and cover it with vinyl with some speaker boxes in the corners.
For those that have done it, what did you make the panel from and how did you attach it? The bracket that the gas tank attached to sticks out a little further than the rear panel below the window. I can build about anything but would like to keep it simple and look finished.
Pictures would be great if you have them.
Thanks
Chris
How did you finish the rear of the cab inside?
-1968 F100 SWB, 4.6 3V, 5R55S auto, Crown Vic front and rear.
-1968 Cougar XR-7, 351C, AOD, Explorer rear. In approx. 6,000 pieces at the moment.
- SSW
Re: How did you finish the rear of the cab inside?
Chris,
I used 1/2" plywood and carpeted it. I made a 3 sided box to cover the bottom (sorry no fab pics of this), and then 2 side pieces that hold the speakers and the back piece. The side pieces I left one corner a little long and it just jammed up into the cab and then I had a L brackets and screwed into the lower box. The back I put a couple straight brackets that pressed in behind the lower box and used black drywall screws and screwed into the back of the cab carefully into the areas where it is the internal metal only. I did put LED's in the side pieces that come on with the dome lights as well. If you look close can see the line from the back piece and the lower box. Turned out great. My seat belts mounting bolts do go through the lower box as well.
Good luck
Good luck
Steve,
Thanks for the pictures. It looks great.
In the finished picture, it looks like 1/4" bolts across the top where the gas tank bolted in. I assume this is where the back piece is anchored in. I was hoping to cover this area but with it painted up, it doesn't stand out like I thought it might.
I'm probably overthinking this, as usual.
Thanks again,
Chris
Thanks again,
Chris
very nice! I was wondering how Ford finsihed the cab off when the truck came from the factory with bucket seats and the gas tank was still in there. Carpet? Paint????
1968 F100 SWB Flareside, 240-6, 3 speed, 3.70 rear, bone stock and rust free.
- 1972hiboy
Ford used carpet and a special set of stainless trim to cover the tank with bucket seats.takehikes wrote:very nice! I was wondering how Ford finsihed the cab off when the truck came from the factory with bucket seats and the gas tank was still in there. Carpet? Paint????
Rich
Dont eat yellow snow.....
I know about the special trim, but cannot find any pictures of it or any for sale.
Anybody know where there is some? I did email a member on here from a post from 2 years ago, but haven't heard back. He must have moved on to other toys.
Thanks again,
Chris
Thanks again,
Chris
- Bullitt74
I would be interested in a "how to" description of how to do the special trim / carpet for the in-cab tank as well. I'm ordering some carpet later this winter, and can order extra carpeting to finish off the tank and firewall.
Steve.
Steve.
Steve F.
Red Deer, Alberta, Canada
'72 Ranger XLT, 4x2, 390-2V, C6, Wind blue & Wimbledon White (‘Smokey’)
2016 F150 Lariat FX4 Supercrew, Ruby Red
Follow my build thread for 'Smokey': http://fordification.com/forum/viewtopi ... 22&t=85070
There are pictures of a Factory Bucket seat truck in this thread:
http://www.fordification.com/forum/view ... =6&t=38215
I've been looking at the 1984-1996 F150 XLT for "idears". Ford did some nice stuff with that.
I've not seen it installed, but Roddoors does interior trims for the Ford F series.
