selecting a torque converter
arkrider410
Post by arkrider410 »
Ok I'm about go pickup my 401 and was wondering what torque converter to pick up can someone please tell how to pick one
It's a 60 over 360 with 390 crank and rods
:fr:
low and ugly 72 longbed with a 360 converted to a 401 with performer intake and a 750 double pumper carb 260 cam and headers with a c6 auto and stock 9 inch lowered about 5.5 /7.
Build thread http://www.fordification.com/forum/view ... 22&t=79488
cep62
Re: selecting a torque converter
Post by cep62 »
There's a lot of varibles in selecting a convertor
Camshaft size and duration ,
gearing.
driving habits and cruising speeds.
you dont want it so loose that it's slipping all the time.
A little more info will help.
arkrider410
260 cam 3:00.1 rear end street driving longbed f100 don't know cruising rpm engine not in truck yet
:fr:
Stock converter will work fine for that.
arkrider410
Thank you but how do you figure that out through
:fr:
arkrider410 wrote:Thank you but how do you figure that out through
Entire books have been written about that... probably ... certainly entire articles....
In very basic terms a "stall" (actually a higher stall or high stall) converter is about getting the engine into the power band. But the total package comes into play, tire height, gearing, vehicle weight transmission ratios...
So if you have an engine with a big cam, single plane intake that is making power at 3500-6000 rpm you're not going to want a 1200 stall converter (probably more like 3000-4000) and conversely if you have a mild cam and a dual plane that makes power from 1000-4500 you're going not going to want a 4000 stall converter.
Also if you're turning 2000 rpm at highway speed, you're going to want the converter working efficiently and not slipping in that range.
Basically the way I figured it out in your case is that it sounds like you're not that far off stock, a 260 (I'm assuming thats something like a Comp 260H) cam is a mild cam you have a pretty tall gear and haven't mentioned anything radical about your truck the stock converter will work fine for that, you haven't changed the parameters enough to cause it to be unsuitable.
You could always call or e-mail Jay @ Broader Performance, TCI, B&M and ATI with all the details on your truck... Exact cam, heads, exhaust, intake carb, compression, transmission ratios, tire size, rear gear and so forth and see what they say too...
FWIW I was not too impressed with TCI converters...
arkrider410
Finally someone explained it to me that can at least understand I've been told I have to get the stall right and I'm was ok how but know I understand it
:fr:
