primer
- 67RED
primer
hey guys. i have been working on my hood. got it down to the metal. i am going to paint it red . i was wondering what would be the best primer color to go with. this may sound like a dumb question. thanks
steve
Life is 90% how you take it10% what you make it
- hardtailjohn
re: primer
Go with a white or at the least grey... and use that color all the way through the project. It's amazing what a difference it makes when you park two rigs side by side in the sun, one with a white primer and one with something else.... the white makes it just glow!
John H.
John H.
Never trust a grinning idiot holding a big hammer!
- Sharkdance
re: primer
I always thought that a dark primer (Black, Red, etc.) should go under a dark color and a light color primer (White, Grey, etc.) should go under a light color.
- hardtailjohn
re: primer
You're right sharkdance...but if you want a red, green, blue, orange or anything like that to really glow, put a white primer under it!! Sometimes they want it to actually be a bit darker, then we use a grey or black primer.
I used the same brand/color paint on 2 identical airplanes and it was really amazing when they were parked next to eachother in the sun. The difference was night and day!
John H.
John H.
- 67RED
re: primer
thanks for thw help guys. i was thinking the darker primer may make the red a little darker than i wanted.
steve
- hardtailjohn
re: primer
Best way to know is to do a test panel. It doesn't take that long and will answer all your questions!
John H.
John H.
re: primer
Hardtail knows his stuff.
re: primer
With my experience the color doesn't mater as much as The quality of the primer. Make sure you use some sort of sealing primer when you are at bare metal. ie not just cheep gray, made that mistake cost me a paint job, talk about rust.
I now go sealer, yellow primer, and three coats red finish, then clear . It will give ya a nice safety red color, very bright, and it last along time.
WHAT ?
- binder56jd
re: primer
i just learned another thing- good info- HTJ thanks- 67 thanks for bringing it up-jd
now serving #235
now serving #235
- Big D's 69
If you use a white primer or a dark primer remember that later on what ever youuse you will have to use that color later. I would recommend gray. That is what we use in our body show. The color of primer tends to change the color of the paint. THe lighter color is gonna lighten the color and the darker will darken it. The gray will leave it a more nuetral color.
- marz68
