Trailer Hitch Question
- bumt72
re: Trailer Hitch Question
Not sure what you meant by "extendable" but my 72 C/S has a barden bumper and the auxiliary tank, it is a long bed and the tank comes nowhere near where the hitch is mounted. The hitch I have on mine is a DrawTite 75034. From a quick search of the web they run around $125.
- TheEskimo
Thanks, the rear bumber pulls out for extended campers. Interesting setup but it only has a few bolts to tighten down to hold it into place so you can't pull anything with it. I may put some kinda pins or something in it so I can pull with it 'case I need to pull someone out of the ditch.
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
- mrung0wa
After several attempts to install a 73-79 class III on Jethro I finally got smart and ordered one from JC Whitney for about $100. I do beleive that it's a Draw-tite and it bolted up like it was made exactly for it (go figger?)!
Of course I upgraded to all grade 8 hardware...
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- TheEskimo
Can't say for sure on yours, but they WERE a factory option on the Camper Specials. I've got some literature around here somewhere that shows them, I'll see if I can track that down.
- HOWDY69
Mine is definitely after market and has two set screws on each side. However, my uncle used it to tow his boat. I am thinking about drilling the rails so I can through bolt it.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
- TheEskimo
