1967 F100 2WD Rear axle driver side binding when bolts or tightened up
- Godspeed128
Hey guys I just install the rear end on my truck put the axle in on the passenger side everything looked great and spins good I moved over to the driver side installed the axel tighten down the four bolts and now it's binding. The only thing I can see is that the passenger side has a washer in between The bearing in the differential housing and the axle bearing I looked at the LMC parts list and I'm not sure I see a washer at all anyone have any ideas on this thanks for any help
Re: 1967 F100 2WD Rear axle driver side binding when bolts or tightened up
I had a wrong bearing retainer once ,and it bound upon on the seal.
- Godspeed128
I just don't see the problem
- Godspeed128
Pics of the side that works I pulled the axel from the other side and exchange them both work no it's not the pressed on Berrings
Also a pic of the side that's binding something went wrong on the side I noticed now that the shoulder where the bearing goes is beveled like something have been eaten away at it
- Godspeed128
Ok all it was is the inner axel seal replaced it and all is fine for some reason the fade of the old one was chewed up
