Amount of fluid to put in rear end ?
Godspeed128
Post by Godspeed128 »
I have a 1967 F100 The rear and has a code 41 on it how do I know how much fluid to put in ?
Jacksdad
Re: Amount of fluid to put in rear end ?
Post by Jacksdad »
Not sure of the capacity (probably a couple of quarts at the most assuming it's completely dry) but when it starts to come back out of the filler hole, you're good.
ultraranger
Post by ultraranger »
If you're saying "41" is the ratio code, I don't know what that is since there's no 41 ratio code listing for a '67-'72 Ford truck.
Is this a Dana rear end or is this a 9-inch? If it's a 9-inch, it will require 5 pints of gear oil. This would be 2-1/2 bottles.
Jacksdad
Post by Jacksdad »
Dana 41?
Ranchero50
Post by Ranchero50 »
You fill it until the oil runs back out the fill plug. :)
I used to use a short clear 3/8" hose on the tip of the quart oil bottles to fill them but have found a small hydraulic gear pump and electric drill works much better.
If it's a 9" 3 quarts will get you there with enough leftover to make a big stinky mess.
