spring pockets from a dentside on a bumpside
arkrider410
Post by arkrider410 »
Will the front spring pockets from a dentside fit on a bumpside
:fr:
low and ugly 72 longbed with a 360 converted to a 401 with performer intake and a 750 double pumper carb 260 cam and headers with a c6 auto and stock 9 inch lowered about 5.5 /7.
Build thread http://www.fordification.com/forum/view ... 22&t=79488
cep62
Re: spring pockets from a dentside on a bumpside
Post by cep62 »
2WD or 4WD?
Top or bottom of spring?
4WD will interchange
2WD I don't know.
Tops are welded and not worth the trouble.
arkrider410
Dentside 4wd tops to 2wd bumpside top
never mind found my answer 4*4 are leaf spring 2wd are coil spring
:fr:
arkrider410
:hmm: ok I'm confused does a 4wd have coil springs or leafsprings
:fr:
arkrider410
Will spring pockets from a 89 bronco fit a bumpside
:fr:
cep62
Post by cep62 »
arkrider410 wrote::hmm: ok I'm confused does a 4wd have coil springs or leafsprings
1/2ton have coil 3/4 ton have leaves.
arkrider410 wrote:Will spring pockets from a 89 bronco fit a bumpside
What are you trying to do??
arkrider410
Will spring pockets from a bullnose bronco fit on a bumpside
:fr:
arkrider410
Trying to get a better ride on my lowered truck without dreambeam cause I can't afford them the po cut half the spring to lower it
:fr:
cep62
Post by cep62 »
The spring pockets are welded on the frame , I suppose you can cut and modify them , but thats a lot of work.
Try and find a "real " spring shop , with dimensions and weight maybe they can match up some springs. ??
arkrider410
The ones on my truck are riveted to the frame and all the ones 2wd and 4wd look to be riveted as well
:fr:
cep62
Post by cep62 »
arkrider410 wrote:The ones on my truck are riveted to the frame and all the ones 2wd and 4wd look to be riveted as well
Maybe , I live in Michigan and I've so much rust and dirt I never really noticed.
If they're riveted, you can use an angle grinder with a cut off wheel to take off the heads and a punch (air hammer) to drive them out.
Use hardened bolts to put it together.
And use eye and hearing protection. (for sure eye.)
arkrider410
Now to get the stuff to do this
:fr:
