70 long box 4spd top loader swap drive shaft to short
I have a 1970 F100 long box sport custom with a 302. I replaced the 3 spd w a 4 spd toploader. after hours of fighting with it I finally got it in only to find the 2 piece drive shaft is to short. its about an inch to short. I was hoping some one knew if there was a car/truck w a one piece drive shaft that would fit.
- sargentrs
Re: 70 long box 4spd top loader swap drive shaft to short
Which 4 spd? Manufacturer/model? Here's a chart showing drive shaft lengths for various different wheelbase/transmission/rear end combinations. If you can't tell it from there, then get the measurement of the front (short) shaft and try to match it up to the Ford part number. From there we may be able to crossreference to other models. http://www.fordification.com/partnos/couplershaft01.htm
I put a Mustang ( 24" ) toploader in my 69 FE ( was 360, now 428 ) truck. The toploader was longer than the short 3 speed that was there. I had a one piece driveshaft made to do away with the carrier bearing. Never had a problem with it that way.
Pete's Ponies
Mustang RUSToration & Performance
- 69timemachine
My truck is a short wheelbase. I took out the 3-speed and swapped in a TopLoader 4-speed and my driveshaft was too long and had to be shortened. I'm not sure why your driveshaft would be too short with a TopLoader? It should be too long.
Jason
'06 Mustang GT 5-speed
