Gear Vendor
redmcode
Gear Vendor
Post by redmcode »
Just wondering if anyone has used a gear vendor and if so what are your thoughts on it? Worth the price? I am looking into one to match up to my 431 and c6. Thanks
redmcode
Re: Gear Vendor
Post by redmcode »
Wow, overwhelmed with all the great replys. Lots to consider now. Thanks for the help.
sargentrs
Re: Gear Vendor
Post by sargentrs »
Lol. I don't any of us that can afford a Gear Vendor's OD set up.
1972hiboy
Re: Gear Vendor
Post by 1972hiboy »
is the money worth the benefits to you? are you paying to have it installed or doing it yourself? I mean smoke em if you got em.
Rich
Dont eat yellow snow.....
Mancar1
Re: Gear Vendor
Post by Mancar1 »
You would cruise out nice, but the cost is $$$$. I have thought about it, but there is a bunch of other things I have on my to do list that are ahead of overdrive. :D
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
HIO Silver
Re: Gear Vendor
Post by HIO Silver »
Overdrive is "better" with a manual trans..... it's more fun than throwing a switch.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
jwright1982
Re: Gear Vendor
Post by jwright1982 »
My brother Inlaw just installed one he installed it at home so no shop fees but he still has a small fortune in it. After it was all said and done he told me he wished he hadn't because of the cost vs what it does. He could have done a manual overdrive twice over for the money. If you have the money to burn go for it but what other things could you do instead.
"Don't be afraid to see what you see"
1968 F-100 240 6cyl 2wd lwb
1973 F-100 360 c6 2wd lwb (parts truck)
2002 Saleen s281 sc (daily driver)
69timemachine
Re: Gear Vendor
Post by 69timemachine »
I had looked into adding a GV onto my TopLoader 4-speed I had, but it was going to cost $3,000 just for the kit with me doing the work myself, and that still didn't include my driveshaft that would have to be shortened.
I yanked & sold my TL4 and bought a brand new Tremec TKO-600 for $2,300 and I didn't need to have my driveshaft modified. With the other $1,000 that I would have spent on the GV, I was able to rebuild my rear axle, swap to better performing gears, and add an Eaton TrueTrac differential.
If you must have an automatic transmission and want overdrive, then the GV is certainly an option, just not the most economical one. A buddy of mine put a GV into his '67 Mustang GTA and he loves it. He wanted to keep it automatic, so that the route he went.
Jason
'06 Mustang GT 5-speed
