BRRRR...
twerp
BRRRR...
Post by twerp »
Has anyone else had the experience of a cold transmission holding a shift longer than normal or jerky between gears?
I have noticed that if I don't let mine warm up for a good ten minutes in the mornings that are 30 or below that when I do leave it holds or jerks a bit. Warm temp is fine.
Any takers? Thanks.
~Michael~
www.dream-logic.com
"It's a whole lot easier to kick down someone's sandcastle than it is to build one... So keep building..."
that could be normal considering the possible age of the transmission. it is always good to let an engine warm up before you start driving it anyway. but i don't always follow that advice either.
newtothefordgame
Post by newtothefordgame »
mine was rebuilt 2 yrs ago and does the same thing, and sometimes when its real cold it won't even go into gear until it warms up. i asked an older freind who has owned ford trucks since the 50's and he told me its not that uncommon and don't worry about it.
Scott
1969 F-100 LWB 360-C6
steveheer
re: BRRRR...
Post by steveheer »
Transmission seals get old and hard--then don't do their job when it's cold. It's caused by low fluid pressure because it's leaking past the seals. I've never really had the problem personally but an OLD c6 truck that a neighboring business has does the same thing, or won't go into gear at all until it warms up. It's been doing that for years and it's still running but it's not exactly a GOOD situation.
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
newtothefordgame
someone told me to try the lucas stop slip transmission gunk, i haven't tried it yet but it is supposed to help.
Scott
mrung0wa
re: BRRRR...
Post by mrung0wa »
When you had your Tranny "rebuilt" the gaskets, seals, bands, steels all got replaced. I'll bet that your case/core/hard parts are the same ones, Right?
A hydrostatic transmission relies on very high pressure and requires close tolerances. When your tranny is cold there are some gaps that with an increase in heat they expand, hence your gaps disappear and it's a happy transmission....
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
marz68
Post by marz68 »
:yt: :bow:
