mc rod removal
drpuffmd
mc rod removal
Post by drpuffmd »
Hi all. First post first ford. Got 1971 f250. Rubuilt the 390 now upgrading breaks.have Manuel drum ft RR. Got new booster and bracket to mount. Pulled off old mc. How do I get rod out. Just pull? Hard!! Hammer? Will anything break. Do I need anything new to install t he new mc to booster or just bolt up. Thanks norm
ultraranger
Re: mc rod removal
Post by ultraranger »
A new MC, meant for a power brake booster and for discs front/drums rear, won't have an input rod that needs removing.
It should just bolt onto the front of the brake booster.
It's not advised to use the old drum/drum MC on a disc/drum application.
The brake valve should also be changed for one that's designed for discs/drums.
drpuffmd
Re: mc rod removal
Post by drpuffmd »
What do you mean disk drum application. I have drum ft n RR. Used old mc for drum drum. Just added brake booster. Should be fine right.
