31 spline vs 28 spline
Think it is about time to build the old 9" for the F100.
Trying to dust to cobwebs off of the prior research.
To recap the truck:
390 - 30 over 10.6:1 with a Crower Street Roller. Desktop Dyno put it in the 450HP range that is probably optimistic.
C6 - ATI fuelmaster, Broader valve body, TCI soft kit VERY firm shifts
On to the rear end - it is a 3.50 open now with 28 spline axles. Plan is to build it with a 3.89:1 or so Detroit Locker. Because I'm really not looking to spend big money on custom 31 spline axles I'm considering using the factory 28 spline axles.
Is that crazy - If I'm not out there trying to drag race it on slicks - am I going to break the stock axles? I haven't broken the stand in Dana 44.
1972hiboy
Re: 31 spline vs 28 spline
Post by 1972hiboy »
oh boy I remember my detroit locker days. Sometimes they miss a spline and skip. you would think you just blew out the rear end. Mine was very street unfriendly in a 9-inch rear end with 3:50.1 , If your not after a smooth ride and not chirping tires around every corner then it will probably suite you just fine. They are supposed to be bullit proof. I think I had the 31-spline rear end and never broke a axle shaft but I wasnt throwing down the same power as you. I did manage to grenande my first DL and break the 9-inch housing. ( ripped the weld around the pumkin and into the axle tube.) :doh:
Rich
Dont eat yellow snow.....
Madman
Post by Madman »
There are an arse-load of 28 spline equipped vehicles out there that are still on the road. I think you will be fine.
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
Madman wrote:There are an arse-load of 28 spline equipped vehicles out there that are still on the road. I think you will be fine.
That is kind of what I think too...
Not so worried about the Detroit Locker manners - truck isn't exactly subtle as it is... :P
ultraranger
Post by ultraranger »
I changed out the 28-spline axles and single track 3.50 geared 9-inch 3rd member in my '69 F100, for a 9-inch N-case 3rd member with a 4-pinion 31-spline Traction-Lok differential with 3:50 gears.
The 31-spline axles came from a 1971 Ford F100 that had a 9-3/8" rear end. 1968-1972 F100s with a 9-3/8" rear end had two different 31-spline axle bearing journal diameters, depending on what differential was in the 9-3/8" rear end.
If the 9-3/8" rear end had a Traction-Lok differential, the 31-spline axle bearings would have a 3-9/64" O.D. x 1-5/8" I.D.
If the 9-3/8" rear end had an open differential, the 31-spline axle bearings would have a 3-9/64" O.D. x 1-17/32" O.D.
The '68-'72 F100 31-spline axles are the same width as the regular '68-'72 F100 28-spline axles.
My stock '69 F100 28-spline axle on the left. '71 F100 31-spline axle on the right.
Stock '69 F100 C7AW-E 9-inch 3rd member with 28-spline single track differential and 3.50 gears on the left. '75 F150 4x4 Daytona 9-inch N-case with 31-spline 4-pinion Traction-Lok differential and 3.50 gears on the right.
31-spline axle installed.
'69 rear brake drum installed.
Even though I don't really think I need it, I am willing to do a junkyard crawl for an N case and 31 spline axles...
Any way to tell if 9 3/4 - 31 without pulling an axle? (door axle codes?)
ultraranger
DuckRyder wrote:Even though I don't really think I need it, I am willing to do a junkyard crawl for an N case and 31 spline axles...
Considering I currently just have a 240 and a C-4, I don't really 'need' 31-splines either but, I have them anyway. :wink:
An N-case may be difficult to find but, a regular Dentside 9-inch 3rd member with a 31-spline differential, Traction-Lok or not, would work with these axles.
First and easiest way to tell if the rear end is a 9-3/8" is to look at the face of the 3rd member. If the top rib curves downward on the left side, it's a 9-3/8".
I don't know if this is a definite identifier but, my stock '69 28-spline axles had two circular grooves on the center register of the axle flange and C8TW-D cast into it.
"Circular" grooves on my 28-spline axle flange.
Except for the casting number, the face of the 31-spline axle is smooth. Casting number on it isC8TW-E.
mrtleavitt
Post by mrtleavitt »
I have a 400 hp 428 and I love roasting the tires and breaking the wheels loose around 30 mph in my power band. I went through probably 5 or 6 28-spline axles. Then I went to a 31 spline rear end from a dent-side truck. I ended up breaking a stock 31 spline axle so I finally coughed up a little $$ and bought some 31-spline Yukon axles and I've never looked back. Now I am leaking oil out of the axle tubes where the leaf spring pads are welded on. Apparently too much torque/bad driving/clutch dumps/ etc. I need to strip it all down and weld everything up. Take it for what it's worth. Good luck!
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
jrpumper
Post by jrpumper »
im doing a 9'' build right now and im staying with 28 spline and i have the following,,,,.030 351 rollerwith comp cm and aluminum heads and a stealth intake and 650 demon and aluminum flywheel and a 3550 tremec i had a 3;25;1 rear gear with a open diff im gonna now have 4;11;1 with a spool
RTG_RACING
Post by RTG_RACING »
I'd stay with the 3.50 rear gear. I had a 3.73 and turned higher rpms than I wanted. I would think a 3.89 would be much worse.
RTG_RACING wrote:I'd stay with the 3.50 rear gear. I had a 3.73 and turned higher rpms than I wanted. I would think a 3.89 would be much worse.
With a 3.50:1 and a 215/75/15 it is below the cruise RPM of the cam @ ~60. With taller tires, which I plan to use, it is going to be worse.
The rev limiter on the engine is north of 6000 and the cam starts making power about 22-2500...
Still, since I'm feeling cheap, I may try the 3.50:1 I can always change it later. :wink:
tnab1970
Post by tnab1970 »
Just for reference: I built a similar set up running a 429 and c-6 , was a " sleeper type" street race =truck. I ran 10.5" slicks on it most of the time and a bottle. truck ran mid to low 13's and was a daily driver. ran the stock 28 spline axles that came behind the 6 cyl that was in in when i got it. , In fact the only thing I did to rear end was remove pumpkin and install a " mini spool". These things are TUFF, Also ran a Mustang for years with 28 spline axles , running mid 11's. I think you will be fine.
