What TOPLOADER am I going to need to look for?
Bullit
Post by Bullit »
I'm sure someone here knows what toploader will do best behind a 70's 429 CJ? (specifics?) I was going with the ZF 5 speed but now am hearing that there's a lot of issues to deal with as far as starter issues, pilot bearing depth issue and flywheel balance issues. Now I'm thinking that just go with the toploader for that era and should have a lot less issues....
Any help?
HIO Silver
Re: What TOPLOADER am I going to need to look for?
Post by HIO Silver »
Read up: http://www.4speedtoploaders.com/
Or go with a TKO-500/600 from Modern Driveline.
SeapineF37
Post by SeapineF37 »
also should check out:
http://www.novak-adapt.com/knowledge/tr ... ateway.htm
they have great info and exp w jeep conversions or stock rebuild. used them for my NP435 rebuild (personal tranny rec)
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
