Hello,
I have a 68 F100 with 360 and C6 automatic transmission. I am changing the manual steering over to power using the Saginaw box. I plan on shortening my existing column, but I need the inner and outer firewall bracket set and seal for a power steering column to get the correct angle. I could also use the shift arm for a power steering column which has the more radical bend in it, although I guess I could just bend mine if necessary. If someone has one of these arms and could trace the profile of it that would be great too, then I could flatten mine and re-bend it to match. Any help would be greatly appreciated.
Need 67-70 power steering column firewall brackets and shift arm.
- OLDYELLAR68
Re: Need 67-70 power steering column firewall brackets and shift arm.
I have the engine compartment side available.
Pm if your Intersted.
- OLDYELLAR68
Thanks for the info Fast65, I have acquired the brackets locally.
