Brake/clutch pedal pivot mount
bkdallas
Post by bkdallas »
I am gathering the parts needed to switch to a manual transmission from a C6 auto in my 1970 F100 with 360 engine. My question: Is the bracket the brake pedal mounts to for a vehicle with an automatic the same as the bracket for a manual vehicle? It looks like the same bracket in the parts manual with the only differences being in the pedal assemblies themselves. Thanks for the info.
sargentrs
Re: Brake/clutch pedal pivot mount
Post by sargentrs »
I believe that is correct. IIRC, the brake pedal portion is the same on both and the clutch pedal assembly mounts as an addition to it. Going from memory when I went from manual to auto and I didn't pay that close attention since I had both assemblies handy.
HIO Silver
Post by HIO Silver »
If planning o go with power brakes, get the booster bracket, booster, and pedal assembly from the same donor due to dimensional differences.
SVT522
Post by SVT522 »
The bracket is the same. On a manual trans truck the brake pedal pivots on the shaft of the clutch pedal. The clutch pedal hangs off the side of the bracket on the left side of it and the shaft goes all the way through the bracket and comes out on the right. The shaft has two flats machined on it and is threaded to hold the arm that attaches to the clutch linkage.
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
bkdallas
Post by bkdallas »
Thanks for the help....one less piece to scrounge!
SVT522
Post by SVT522 »
FYI - the 67 pedal and bracket are unique to that year.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
