What size line does the vac booster need from the manifold?
motzingg
Post by motzingg »
pretty simple question... looks like the hose that was on my booster was 1/2" maybe? seems like over kill, i'd like to run a 3/8" hard line to clean up the install. Would that cause problems?
HIO Silver
Re: What size line does the vac booster need from the manifold?
Post by HIO Silver »
A hard line would be fine but it'll need a section of hose to take up the engine's vibration. The hose should also be reinforced against collapsing due to the applied vacuum.
