The right Toploader trans for FE 390?
Motörhead1972
Post by Motörhead1972 »
Correct me if I am wrong but can you use a 3 spd truck or 4 spd car toploader from a windsor and bolt it safely behind a 390 FE? Been around 302's and other windsors my whole life but never an FE. I already have the correct FE bellhousing. Wikipedia says they both use the same input shaft of (1 1⁄16) and 10 input splines. If not, what will I need to look out for?
This will be going in my 62' gasser project 8)
Thanks.
1972 Ford F100 Custom LWB. 302. RAT 3.03 wide ratio with Hurst shifter. 3.25 rear end.
1962 Ford Falcon Ranchero (Project)
tnlprt
Re: The right Toploader trans for FE 390?
Post by tnlprt »
To use the car small block toploader behind a 390 FE engine you will need the 390 Truck bellhousing
The SB toploader has a longer input snout where it goes into the pilot bearing
If you use a car FE bell housing with the SB trans the input will bottom out and eat the thrust bearing out of the engine
