Whirring Sound...
Whirring Sound...
Hello all, I have a 1972 F250 and it has been making this whirring sound. I tried reading into it and most of the other posts have been about the pinion bearings in the rear differential.. all i read online was that if i got under my truck and if the drive shaft moved at all when i shove it around, then that was the indicator of worn out pinion bearings. I did this and nothing under my truck was loose. -also im not sure if that is the only way to check the bearings, it was just the most common way that everyone recommended. I tried moving tugging and pulling on everything under there and everything felt good. But, this whirring sound persists and i was wondering what else could cause this sound? It only happens when I am in motion, as I accelerate, the whirring sound speeds up and as i decelerate, it does accordingly. If you guys could help me out, i would appreciate it!
- BobbyFord
Re: Whirring Sound...
Maybe a front wheel bearing or rear axle bearing. I would pull the wheels and inspect/spin each hub.
Did you have the rear end off the ground and the transmission in neutral when you checked the drive shaft and rear end
I'll check the back hubs next.
But, no i didnt do any of that when i checked the drive shaft.. that the proper way of checking im guessing..
