Hi All, I have a '71 390 reuild and am looking for the 2 groove crankshaft pulley for just waterpump/fan/alt and factory power steering. I believe the part number is C8AZ-6A312-C (sometimes called C8AE-6312-C also I think). It is the one on the far left in this photo. I have a 4 groove setup (1 groove plus 3 groove for the A/C that I removed) to trade if need be.
Thanks,
Patrick
FE 2 groove power steer crank pulley
- patrickdotryan
1971 F250 Custom
Camper Special
Prairie Yellow
390 (was a 360), C6 Auto, Dana 60
Camper Special
Prairie Yellow
Re: FE 2 groove power steer crank pulley
I will check and see what I have lying around, but it will most likely be after Elk HUnting Season! Like Mid-November.
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
i have one i'm pretty sure but i need to know exactly what you are looking for. are you looking for a pulley with an inner sheave and a blank and an outer sheave. the same width as a 3 sheave pulley but with 2 pulleys on it.. one inside and one outside?
jim
jim
- patrickdotryan
Hi Jim,
Thanks. I'm looking for C8AZ-6A312-C / C8AE-6312-C and the closest eyeball I can give you is in the photo above (leftmost pulley) I don't know the total depth of the whole pulley assembly or casting, but you're correct, it is a larger sheave closer to the motor (for the fan/water pump/alternator) then a space (maybe 1/2" - 3/4"?), then a slightly smaller sheave (for the p/s) closer to the radiator. The pulley diameters I pasted from the pulley parts page on this site are as follows.
#C8AE-6312-C - double sheave
6-21/32" large pulley dia.
6" small pulley diameter
Inner pulley uses 3/8" belt
Outer pulley uses 1/2" belt
My motor is sitting waiting for this part, so I would love it if you had one. I assume they're pretty common as they go on lots of motors, just probably most don't have 'em lying around.
Cheers, Patrick
Cheers, Patrick
1971 F250 Custom
Camper Special
Prairie Yellow
Camper Special
Prairie Yellow
i have one. send me an email and i'll send you a pic if you are still looking. kansastomatoes at sbcglobal dot net.
jim
jim
- patrickdotryan
Awesome, just sent. Thanks, Patrick
1971 F250 Custom
Camper Special
Prairie Yellow
Camper Special
Prairie Yellow
