302 flywheel problems
67 ford f100s rule
Post by 67 ford f100s rule »
So this last week the clutch in my 70 f100 with 302 and 3 speed overdrive went out. I pulled it apart and the flywheel is pretty badly heat scored and pretty worn. but I cant seem to find a correct replacement flywheel. Has anyone else ever had this problem?
edit it seems that the flywheel I have is made for a diaphragm style pressure and not the long style or lever style pressure plate. I am looking all over but I just get conflicting information.
so here is where I stand, I already have a lever type clutch set. I also already have the wrong flywheel. the original clutch was an 11 inch lever type. but my experience resurfacing flywheels tells me mine is probably toast. So does anyone have an idea on the correct flywheel I need to get?
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
68RGR
Re: 302 flywheel problems
Post by 68RGR »
Can you spot a part number on the flywheel?
If so, you can work backwards from the parts list to see what engines/vehicles it was used on. That's the only idea that comes to mind other than just getting a matching set.
I'm guessing the engine and/or transmission may not be original to the truck.
Bill
68 F100 Ranger
73 F100 Ranger XLT
Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in garages. (Apologies to Kenneth Grahame.)
