I completed my overhaul including synchros on my NP435 4 speed out of my 70....I found that the synchros for 3/4 that came with the kit to be a bit clumsy, the collar didn't fit over the dammit (can't remember the real name or term) retaining the synchro itself very well....long story short it would not allow for proper clearance of the shafts and would result in binding and then locking up of the rotation....using the new syncho gears in the old collars rectified this, and all seems right with the world.....I got the kit from Jeff's Bronco Graveyard, not faulting them, but the parts are stamped "Made in India" so I expect lower quality from such....
Hope this may help someone out...Pics to follow
New Process 435 Overhauled today, potential FYI
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
Re: New Process 435 Overhauled today, potential FYI
Are you talking about this lovely setup?
This is as true an straight as i could get mine to sit, even in the trans. Truck wouldnt go into 3rd every time
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
I am not sure about lovely, but that is the one....I cut the 6 black rivets or extensions (they aren't bolts) and pulled out the synchro, I used the old collar and metal caps from the old parts, coupling them with the new synchro and replacement sliding gear... now it shifts and rotates as it should but as I am a ways from running until my resto is done, I really won't know if its the answer or not, I think it is, but being sure is nice!
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
I had to buy a new one. Mine was toast, was some off brand re-pop an it didnt mess/slide right as it should. New old stock in its place now, should be tons better.
-Mike-
ECV 1849
ECV 1849
