Where do you guys get your replacement speedo cable? The one I ordered from LMC was not the correct one.
Old of course is the nasty one not in the bag
Here is LMC's cables. Based on my '68 2wd 3 speed non-overdrive I need 47-2032. That is not what is in my truck.
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=90
Replacement Speedometer
- cghstrojan08
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
- Mancar1
Re: Replacement Speedometer
Napa if u got one anywhere near. Gear and cable r usually sold separate.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- cghstrojan08
Well went around town yesterday. Only place that had it was O'reilly but they had to order it. Got it today and put it in. Works great but while I was out getting gas for the mower the truck decided not to start. Its always something.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- Mancar1
Yes it is. Mine was down off and on the past few days. It turned out to be a loose wire on ign switch. Easy fix once I found it.
These older vehicles required more maintenance to keep them going, but when they go down it is cheaper to repair than modern vehicles.
Hope your problem is nothing serious.
Keep on Trucking....John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Ranchero50
Visit your local NAPA and quit ordering repair parts from LMC. No shipping and the returns are much simpler.
The part in the bag looks to be for a cruise control truck.
- cghstrojan08
Local Napa said they couldn't help me. O'Reily seems to have most things. Only reason I got it from lmc before is because I was ordering other things.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- Ranchero50
That weird, I've never had trouble getting them from them.
is there some sort of aftermarket difital speedometer to hook onto the existing speedo gear opening? i guess somehow they would still nees the speedo gear
cghstrojan08 wrote:Where do you guys get your replacement speedo cable? The one I ordered from LMC was not the correct one.
[ Image ]
