GM power steering pump
abyars111
Post by abyars111 »
I've heard some folks mention using a GM power steering pump. Has anyone done this? What are the benefits? How would one accomplish this? What donor vehicle would the pump come from? I don't have any problems with my PS, I'm just curious.
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
elgemcdlf
Re: GM power steering pump
Post by elgemcdlf »
What engine do you have? Lincoln used the Saginaw pump on their 460 engines.
abyars111
Post by abyars111 »
I have a 390. I've found a few aftermarket brackets.
Anthony
70shortwide
Post by 70shortwide »
Not sure if the vans even came with fe engines... But it is my understanding that they all came with Saginaw pumps. Could be a good place to source the brackets.
abyars111
Post by abyars111 »
Thanks. I never thought of that.
Anthony
No, vans never had an FE.
HIO Silver
Post by HIO Silver »
I'm gonna swap to a Saginaw (canteen) pump using CVF brackets on my 4WD '73. The Ford pump, at least the one I have sourced from a 360FE, 2WD '75 F150, doesn't put out enough pressure for my 78/79 steering box. It's "lazy".... the RPMs need to come up before there is 100% power steering.
I sourced the pump off a 76 GMC 4x4. The Saginaws are tuned pressure-wise by GM according to the weight of the vehicle so it is best to source one from a similarly sized/weighted vehicle.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
abyars111
Post by abyars111 »
HIO, do you know if the pressure side fitting on the pump is different from Ford's hose?
Anthony
HIO Silver
abyars111 wrote:HIO, do you know if the pressure side fitting on the pump is different from Ford's hose?
I don't recall the fitting size but the guys at PSC Motorsports will know... I'm planning to get the hose and field-serviceable fittings from them.
http://www.pscmotorsports.com/
abyars111
Post by abyars111 »
Those are cool fittings. Thanks.
Anthony
