HELP! Countershaft gear blocking input shaft bearing
d-tree
Post by d-tree »
My manual says to drop the countershaft assembly out of the way so that the input shaft (with bearing still on it, from what I can tell) can come out through the top of the tranny. It drops down, but is still blocking the hole by about a sixteenth of an inch (or less, it's driving me crazy). :hw:
Anyone familiar enough to tell me what I'm doing wrong?
'69 F100, 360, 3.03 RAT on the tree
fmartin_gila1
Re: HELP! Countershaft gear blocking input shaft bearing
Post by fmartin_gila1 »
pull countershaft completely out to the rear so the cluster gear can drop to the bottom of the case and you should have enough room.
Fred
