c4 vacuume lines
Blue1971FordTruck
c4 vacuume lines
Post by Blue1971FordTruck »
i need to know how and where the vacuum lines go to the transmission in a 1971 ford f100 rwd, c4, bolted to a 302 help please mine is missing need to know all specs on it
im assuming its a metal line (similar to a metal brake line ) diagrams and pictures of how you have yours please and thank you :drive: :drive: :drive: :bdh: :bdh: :bdh: :bdh: :bdh: :bdh: :bdh: :help: :help:
Mancar1
Re: c4 vacuume lines
Post by Mancar1 »
Run a Vacuum line, from the modulator on the trans to the manifold you need full time vacuum. If you have metal lines they should be trans cooler lines. You can Google C-4 trans vacuum line.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
sargentrs
Post by sargentrs »
Blue1971FordTruck
n o its the wrong transmission and my truck has no open vacuum spots on the intake
Mancar1
Post by Mancar1 »
Blue1971FordTruck wrote:n o its the wrong transmission and my truck has no open vacuum spots on the intake
How about off the carb, or installing a tee :?
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Blue1971FordTruck
can you or anyone post a picture of how this is at the intake and at the transmission
and a diagram of the vacuum lines on the intake i have a1972 ford 302 two barrel carb connected to a c4 automatic rear wheel drive
