factory tool box
smoking79stang
factory tool box
Post by smoking79stang »
does anyone know where to find a lock for a side tool box for a 69 F-100
warning: objects in mirror appear to be losing
i would think a locksmith would be able to get one. the one here in town sells them for bed crossover toolboxes.
Heavenlyfire
Post by Heavenlyfire »
any hardware store should sell locks. I had to get one for my old truck and went to Home Depot for it.
mcarlson11
re: factory tool box
Post by mcarlson11 »
just get a lock from lowes/home depot, they are for drawers, but work just fine, since its the same type of lock.
1970F250
Post by 1970F250 »
:yt:
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
smoking79stang
I was thinking about a regular lock, but was just wondering about a repro of factory lock. Thanks guys
thats what i was talking about. was the factory replcements. they are normal locks that can be replaced with modern day locks. not a hasp and a padalock. a regular cylinder type lock. from a locksmith. is where i got my crossover box locks. same as what you want.
Aesop
Post by Aesop »
Excellent. I just bought a sweet bed from a 68 F100 and it's lock is also ruined. However I have another question. I am mounting this box on my 67 F250 4x4, will there be a interferance problem? On first glance it looks like it will fit but I never see that toolbox on 4x4's. Just wondering.
67 F250 4x4
michaelbrainard
Post by michaelbrainard »
I need hinges for that door. The door at one point got ripped off my tool box...only one hinge remains. Anyone know where I coudl get a couple???
smoking79stang
I installed the box from a 69 f100 and the tool box wouldn't clear. Had to install a body lift, so i put 3". Don't know if less would work.
Aesop
Post by Aesop »
What does it hit on? Can I modify the toolbox and do without the lift?
67 F250 4x4
smoking79stang
The tool box will hit on the spring perch. You could probably modify the tool box, by cutting a section out of it.
smoking79stang
smoking79stang wrote:The tool box will hit on the spring perch. You could probably modify the tool box, by cutting a section out of it.
correction spring hanger, not perch.
