identification help on a 1961 F100 rear differential
chisum5013
Post by chisum5013 »
Can someone help me identify the type and specs on this tag that was on the rear end of a 1961 f100 with a 223 six cylinder engine. Please see attached photo Also, what kind of fluid do I use in it? Thanks for your help in advance.
Donnie
Re: identification help on a 1961 F100 rear differential
Post by Donnie »
My photo isn't clear, but I think that it reads C1TZ>>>>>>> that indicates that it is a 1961 ......the 3:70 is the rear end ratio..
I would think that 90 weight gear oel is OK to use.......other opinions may follow......Donnie :2cents:
ultraranger
Post by ultraranger »
Donnie wrote:My photo isn't clear, but I think that it reads C1TZ>>>>>>> that indicates that it is a 1961 ......the 3:70 is the rear end ratio..
Yep. This same topic had also been posted in the General Discussion section, which is where I had made my replies to it yesterday.
http://fordification.com/forum/viewtopi ... =2&t=73233
