Threads shot steering column
69Ford
Post by 69Ford »
Just took the steering wheel off my 69F100. Was converted to power steering. The threads are very poor shot on the column shaft. Wondering if anybody
has one. Automatic Transmision Ford Saginaw power steering box. Out of time I will take pictures. Thanks
69Ford
Re: Threads shot steering column
Post by 69Ford »
Now I'm further into my steering column. I need help. How do I separate the colum from the rag joint and how do I remove the transmission linkage. I removed the 3/4 round clip. Also feels like the lower bearing in the column is shot. Any info would be helpful Thanks my first time doing a project like this
sargentrs
Post by sargentrs »
To remove the column flange from the rag joint, just remove the two nuts on top. On the linkage, once you've removed the "C" clip, the rod just pushes out. Here's a tutorial on rebuilding a steering column. Hope it helps. http://www.fordification.com/forum/view ... =5&t=72274
69Ford
Post by 69Ford »
Thank you for the link. I won't get back to the column till tomorrow. took the two nuts off won't budge thinking now its just rusted togehter.
