clutch stuck to floor
storm72
Post by storm72 »
left work and truck started " jumping " in gear came to a stop sign ( never left first. gear) tried to let out on the clutch and it was stuck to the floor and won't come back up had to let it roll back down the hill into a parking lot where i left it until i can get it home. any ideas on what could cause this
me and this truck :hw:
72 f100 lwb 302 3speed
78 f100 swb 351m auto edelbrock 600cfm Carb (electric choke) & intake
sargentrs
Re: clutch stuck to floor
Post by sargentrs »
Pretty much gotta be the somewhere between the clutch pedal linkage rod and the z-bar. Either the linkage rod came out of one of the pivot points, the z-bar bearings gave out and it came out of it's brackets, the push rod came out of the clutch fork or the tension spring broke or came loose. http://www.fordification.com/tech/image ... dals02.jpg
storm72
Post by storm72 »
went to look at the truck today and found this laying in the road
https://fbcdn-sphotos-e-a.akamaihd.net/ ... 3990_o.jpg
storm72
Post by storm72 »
sargentrs
Post by sargentrs »
Ugh! Looks like z-bar bearing failure. In either end of that pipe with the levers welded on it are pivot bearings. They're swivel bearings with a ball shaped nylon cap. The nylon part just sticks in the ends of the pipe and the mounts on the engine and frame capture and contain it into a single assembly. If the bearing fails, the nylon disintegrates or the nuts back off or the bracket breaks, it just kinda falls apart. There's a bracket bolted to the top rail of your frame on one end and a bracket bolted to the block on the other (might be cast into the block if its a.small block). The design is to allow for the flex of the engine during normal operation. Take it.loose from the frame and the block and get it out to where you can see what actually failed, then you can figure out what you need to fix it. Probably this http://www.fordification.com/tech/67-72ID_01.htm That's for a mustang but I think they're the same. Maybe this too http://cgfordparts.com/ufolder/fordpart ... UZ-7A535-A Sorry for the scattered reply but I'm on my phone n its hard to copy n paste. :wink:
storm72
Post by storm72 »
well got it back together enough to get it home , but i noticed the nut on the driver side motor mount has come off. wonder if that could have caused my " jumping " problem and caused the linkage to fall apart along with it being worn out and rigged
at least its home and i didn't have to have it towed :lol:
storm72
Post by storm72 »
sargentrs
Post by sargentrs »
Gotta love these trucks! You can just about always limp home with a little creative thinking. The nut coming loose would definitely do that. Put it back together tight and have someone work the clutch while you watch it. If it looks good run with it. :thup:
