Tranny seal Leaking
69Ford
Tranny seal Leaking
Post by 69Ford »
The tranny seal on my truck is leaking the one on the output shaft next to the Ujoint Just want to know how hard it is to fix can I take the four bolts out in front of the odometer cable
without anything unexpected happening. heres a picture. Don't know anything about tranny's Thanks C6
Donnie
Re: Tranny seal Leaking
Post by Donnie »
to just replace the seal, remove the driveshaft, then the nut that holds the rear yoke in place, pull out the yoke & your seal is right there, pry it out. To answer your question, yes you can remove the ex housing after removing what I mentioned, but you don't need to.....Donnie
69Ford
Post by 69Ford »
Thank You
BobbyFord
Post by BobbyFord »
...also, use some Brakeclean on the splines of the output shaft and on the splines of the bolt-on yoke, make sure it's oil free and dry then after the yoke is in place on the output shaft, run a bead of silicone where the splines join, before putting the yoke nut on. If not, the trans fluid will leak past the splines and past the nut.
69Ford
Post by 69Ford »
Good Info Thanks to everyone out there who cares about these trucks.
