AOD SHIFTER HELP
GOODOLEBOY84
AOD SHIFTER HELP
Post by GOODOLEBOY84 »
Hi I have a 72 f100 im installing a 351w and aod in, im not quite sure what to do about the shifter linkage, what are you aod guys doing, i would like to keep my factory column shifter and not have to convert to a floor shifter
Thanks, Dustin
Broncobilly66
Re: AOD SHIFTER HELP
Post by Broncobilly66 »
Bump for ya. I'd like to see too
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
GOODOLEBOY84
anybody?
j41385
Post by j41385 »
Sorry I missed this earlier. I got an aod from a 1993 F150 and it was designed for a shift cable. So my trans guy hooked it up with a shifter linkage from an 80s model designed for a vehicle with a shifter rod. As for the stock column shifter, our trucks weather they had a c4 or c6 the shift pattern is PRND21 the aod's shift pattern is PRN(OD)D1 so I just a lable maker to put od over the original D, and D over the 2. This setup works great for me.
Image Image
GOODOLEBOY84
so did you change the shift lever in the transmission to the 80's aod?
thanks Dustin
j41385
Post by j41385 »
Yes, that way I have the good aod, and it would hook up to my column shifter.
Image Image
