Z BAR
SHEP-F100
Z BAR
Post by SHEP-F100 »
Will I be able to use the stock z bar from my 360 3 speed to my new 460 4 speed toploader?
carbine2
Re: Z BAR
Post by carbine2 »
I'm not very knowledgeable on the differences of different transmissions but as far as I know you can use the FE Z bar on a 460 swap. You will need a bracket with the plastic pivot point that bolts to the bell housing as a 460/429 does not have the mounting holes for one. I'm still stockpiling parts for my 429 swap so I can't comment on how well any particular parts work but I did get a bracket for this from L&L that looks promising. Mine was a 435 trans though and I don't know if the Z bar is the same as yours.
Allen
Some people are a lot like a slinky. Generally useless, but fun to watch when you push them down the stairs.
1969 F-250 Crew Cab 2WD
1969 F-250 Crew Cab 4X4. Under construction.
1972 F-250 Crew Cab 2WD. Stolen in 2002. Still looking.
