67 m/x cruis-o-matic
Can I disconnect the water cooling lines to my 67 m/x cruise-o- and let it run air cooled without damaging the tranny ?
- bluef250
Re: 67 m/x cruis-o-matic
Why?
How do you use truck?
Around town light hauling. It's a lot of hose snaked around. Will it work fine being air cooled
This would be the best place to get a answer http://www.fordification.com/forum/viewforum.php?f=4
NO, WHY WOULD YOU WANT TO ?????????????????//
Ford DESIGNED the transmission to be OIL cooled. It was not designed to be air cooled, so no way will your transmission last if you disconnect the lines.
If you want to replace/rebuild your transmission every few hundred miles, then leave the lines disconnected. HEAT is the biggest enemy for automatic transmissions. The hotter they run, the faster they burn up.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
- colnago
Agreed. There is no reason to run it air-cooled, and every reason NOT to. All auto trannies should be routing their fluid to a cooler of some sort (no experience with manual trannies, but I assume they are the same).mmerlinn wrote:HEAT is the biggest enemy for automatic transmissions. The hotter they run, the faster they burn up.
Joseph
