Gear Vendors OD any thoughts?
AJ Brooklyn
Post by AJ Brooklyn »
Hello to all,
I have a 67 F100 SWB she runs good with the built 390 and t-10 4 speed but i'm thinking about a Gear Vendors OD unit, does anyone have experience with this set up?
It looks great on paper but i'm wondering how good it is in the real world, The OD is really expensive and i need some input before i lay out that kinda cash. Thanks
44Bulldog
Re: Gear Vendors OD any thoughts?
Post by 44Bulldog »
It works awesome.......one of the best upgrades I have ever done......
My 2 cents..
cbfomoco
Post by cbfomoco »
I looked into this for my ton truck. For my application it is not quite as great. If you are wanting to split gears i.e 1st 1st over 2nd, 2nd over, etc will not enguage till about 25-28 mph. I think installation and the product are good. I think the fluid has to be changed about every 3000 miles or so and is a synthtic type fluid. I am wanting it to split gears and have overdrive. For me the advance adaptors ranger overdrive unit is the way to go. I have debated this alot but with 4 ton on the truck I want to split gears if possible. For just a driver/ fun/ drag type veh the gear vendors is likely they way to go. Also from my reading there is a slight delay when it shift and can be pretty firm as I dont think you have to clutch it. I have looked into alot of different overdrives options for my application/useage and could have jumbled some information up. But is still a good option and I think a good product. Hope this helps. I dont know how a 5 or 6 speed compairs in price it would only be one unit to service vs 2 with the gear vendors and I dont know about driveshaft setup/lenght with a 4 speed and overdrive vs a later/newer 5 or 6 speed tranie.
1994 F150
1968 Bronco
1968 F350
1958 F100 Great Grandfathers Last Truck
1954 F100 Dad's First Truck
gregamorton
Post by gregamorton »
I like mine but its behind a c6.
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
gregamorton
I spoke yesterday without ready that you had a f100. What gears do you have in truck now? How do you use truck? I would never have any thing lower than 3.00-3.25 gear in a driver especially with a 390. My buddy is working on a unibody and they added a 390 4 speed and it screams on the hwy. It has factory 3.90 something gears in it!
