limited slip has too much slip
rkingdave
Post by rkingdave »
Hi, my 89 f150 with a 3.55 8.8 Limited Slip diff seems to slip too much in my opinion, what can be done to help tighten it up??
Donnie
Re: limited slip has too much slip
Post by Donnie »
Dave, how are you making this test?...What makes you think that it is not working correctly?.........Donnie
rkingdave
Post by rkingdave »
I recently had to park on a grassy incline, while going back up it it just spun the rr wheel all the way up it. is there any additive that might help it?
ultraranger
Post by ultraranger »
Sounds like it may be time to replace the steels and friction discs inside the differential. Traction-Lok differentials should also have 4-ounces of friction modifier added to the gear oil.
