Hey everyone,
This is my first time pulling a motor, tranny... I was thinking that the drive shaft should just come out of the tranny as I pull the motor and tranny out... Is that a fair assumption on my part of is there something I need to do with the drive shaft before hand?
Appreciate you looking and reply if you do...
Pulling Motor, C6 Out Together - Will Drive Shaft...
- Art
Re: Pulling Motor, C6 Out Together - Will Drive Shaft...
Some C6 transmissions have a slip yoke at the back while others are a bolt-on driveshaft flange. Better look at it more closely...
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
- flyboy2610
I would strongly recommend removing the driveshaft before pulling the motor and tranny. Make a paint mark on the side of the driveshaft and tranny tailshaft so you can get everything lined up properly for re-installation. Also do the same for the driveshaft and rear end yoke.
Get a big pan under there
the transmission tends to spill oil out of the rear/tail when the slip yoke is removed, or from the hole for the speedometer cable..
If your worried about fuel prices a Big Block Ford is not for you...
Thanks everyone... appreciate it.
