71 f100 will shift into drive, but not back into park
booblinker
Post by booblinker »
I can shift into reverse, neutral, park etc, but I can't shifts back up to reverse from drive, or park from reverse. I have to pop the hood and pull the linkage up to put it into park.
1969 F250 High Boy 360 4 speed
-3" Body Lift
-36x12.50 tires
-Edelbrock Intake, Mallory Distributor and coil, long tube headers, and true duals with flowmasters
-Who knows what else I haven't figured out
-1993 Ranger 3.slow 4x4 DD
-1971 F100 302 auto
-1985 Tri-z
-ATC70 with a 125 motor
-A few 200s's
basketcase0302
Re: 71 f100 will shift into drive, but not back into park
Post by basketcase0302 »
booblinker on Sun Nov 04, 2012 1:02 pm
It sounds like you might have already troubleshooted it to be in the column if you're able to go back into park with the linkeage unhooked? You are still using the column shifter aren't you or do you have a floor / aftermarket type shifter? Does the selector shaft, (shaft coming out of the tranny where the linkeage hooks to part#7228 in the below schematic) shift through all the gears with the linkeage rod unhooked? If so then try to see how much resistance the shift collar, (collar surrounds the steering column) has with the linkeage unhooked. Here's the steering column schematic that also might help:
