72 Sport Custom Finished
Show us your rides or projects!
AZHobie
Post by AZHobie »
Just finished my 72 F100. Replaced floor pans, radiator core support, drivers door and fender. Rebuilt the carb and tune-up. Replaced front windshield, rubber seals, anti-rattlers, all rubber seals as well as new side trim,new steering wheel and instrument cluster clear panel. Added new carpet and seat upholstery, insulation all the way up behind the fuel tank. I changed out original vinyl door panels for some steel ones I found on ebay and painted to match. Also replaced cab mount rubber and bed bolts. That was a tough job. Underneath was pretty clean so since this is a daily driver I left it alone. Everything else just needed alot of sweat equity. Painted in the Seapine Green and Wimbledon White. Also called Med Metallic Green or Saphire Green. This was the original factory color. Truck has 360 automatic, power steering, brakes and factory air conditioner which works and was converted to R-134. I also removed the original Tecumseh compressor isolation valves during the process. Have a new power steering pump to install soon as well as to figure out the brake warning light problem. Installed a bulb and it lights up. I will check the H block and sensor and bleed the brakes to see if this solves the problem. Engine and transmission was rebuilt at 92K miles in 1992 which was about 15K since. Compression was pretty solid at 130 psi accross all eight cylinders. If the engine craps out, I will rebuild to a 390 4 barrel with cam. Original single exhaust which I think I may keep. Kind of nice to have a quiet ride. I sure like these old trucks and the restoration provided some badly needed mental restoration as well.
BobbyFord
Re: 72 Sport Custom Finished
Post by BobbyFord »
Very nice looking truck! Good job :thup:
tybob81
Post by tybob81 »
Love it! Nice job on the restore!!
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
guerra
Post by guerra »
That truck turned out great. I am not a fan of green, but with the white it works. I'm digging it!! :thup:
1967 f-100 lwb 360/c6
1969 f-100 swb 351/c6 (project)
jimmy828
Post by jimmy828 »
i'm impressed!! :thup: :thup: Is that boxwood green? If so, i'm glad to see it because that is the color my truck is suppose to be. I am a long way from from getting to the paint stage though :( Love the color. Sorry, went back and read your post. I see the color of green. Still a very nice color!
Kraig
Post by Kraig »
Nice truck!!
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
elmo34
Post by elmo34 »
She's a beauty!
basshound71
Post by basshound71 »
Very nice! :thup:
1971 Ford F100
2007 Chevy Avalanche
69SCJ
Post by 69SCJ »
My goodness that looks great!!!
68 f100, 390, 4x4, NP435, LWB, 33/12.5/15's, power steering.... work in progress!!!
tylerb43
Post by tylerb43 »
That Sir, is a beautiful truck!! Wow, thank you so much for sharing! :clap:
Any more pics of the before and/or during?
sargentrs
Post by sargentrs »
Great job! A true inspiration.
AZHobie
Post by AZHobie »
Thanks for all the good comments. Obviously I am an amatuer and completed all the work except spraying the paint and welding. Truck was relatively solid to start with.
shango
Post by shango »
Looks fantastic! :D
1967 F100 Long bed/352cid/ Warner T-18 4-Speed
ezernut9mm
Post by ezernut9mm »
that's kind of a rare color. nice work too. where did you get the carpet from? looks perfect.
fbomb100
Post by fbomb100 »
thats a nice truck,, good work
