cigarette lighter
cigarette lighter
i need a lighter outlet in my truck so i can plug stuff up. i'm about to order some things from npd. is this what i need to start? going to put one where there is a silver disc covering a accessory hole on my dash. probably for a outlet
http://www.npdlink.com/store/index.php? ... F-15055-2A
lmc can sell the entire cigarette lighter with dash bezel and lighter element for a 72
- Montana71-F100
Re: cigarette lighter
i ordered the one you found. much cheaper! thanks! good find.
- 71PA_Highboy
Yep... a Dennis Carpenter part... same pic as their catalog...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
You may already know this, some trucks also have a light that clips onto the lighter socket, plugs into the lighting circuit.
that sounds like a junkyard piece. time to start searching72BahamaBlue wrote:You may already know this, some trucks also have a light that clips onto the lighter socket, plugs into the lighting circuit.
that piece i ordered on ebay is junk. it doesn't work. don't order cigarette ligthers from that guy. going with a cheap orange illuminated one from oreillys. should have it done today along with my trailer pig tail. and then need to wire up the choke since my ghetto choke rod dissapeared somewhere. and adjust the timing and the idle... yarg! every time i leave my truck sitting it adjusts itself and breaks a few things
- kf7mjf
Do tell?72BahamaBlue wrote:You may already know this, some trucks also have a light that clips onto the lighter socket, plugs into the lighting circuit.
1967 F-100 Ranger
i have two of those light clips. i tried to donate them on the forum but didn't get any bites. if you need one kf7mjf i will gladly donate one.
and the cigarette lighter that i said did not work that everyone should avoid buying - it keeps blowing fuses no matter how big they are - that's why i say they're CRAP!!!!!
Are you sure you wired it correctly? I went through the same problem when I replaced my cigar lighter. I connected both wires that were attached to the original to the new one. Turns out only one of those wires is for the cigar lighter. The blue-white stripe wire is power to the cigar lighter, and the blue-red stripe is for the clip on light. It would blow out my dash light fuse, and I couldn't figure out why. The one you bought from ebay is supposed to be grounded separately like mine. Take the blue-white stripe wire and connect it to the center lead, then make a ground wire with a 1/4" spade terminal on one end and a ring terminal on the other. Connect the spade terminal to the other lead on the cigar ligther, and the ring terminal to a good ground. Replace your blown fuses and you should be good to go.
The original grounded through its connection at the dash.
Common Sense is an Uncommon Virtue
The light plugs into a single female bullet pigtail (light blue/red stripe).kf7mjf wrote:Do tell?72BahamaBlue wrote:You may already know this, some trucks also have a light that clips onto the lighter socket, plugs into the lighting circuit.
crappy one from oreillys works fine. expensive on on ebay = crap. thanks ebay you continue to disappoint me. except for my alternator which is the only good ebay dice i've rolled for this truck
Hello hedz, I have unique mixture twice and still not managing so have taken to my Little store presently for them to kind as still under assurance. I am having concerns discovering an adaptor that fits the non smoking huge I have three but nine fit? Can anyone let me know which kind of adaptor will fit the non smoking huge or offer me a weblink to where I can buy one?hedz wrote:i need a lighter outlet in my truck so i can plug stuff up. i'm about to order some things from npd. is this what i need to start? going to put one where there is a silver disc covering a accessory hole on my dash. probably for a outlet
lmc can sell the entire e cigarette lighter with dash bezel and lighter element for a 72
- thejunkman
Joyous wrote: Hello hedz, I have unique mixture twice and still not managing so have taken to my Little store presently for them to kind as still under assurance. I am having concerns discovering an adaptor that fits the non smoking huge I have three but nine fit? Can anyone let me know which kind of adaptor will fit the non smoking huge or offer me a weblink to where I can buy one?
-Dave
1967 f100 long bed 2wd, 390, np435
1999 Mercury Grand Marquis
X2thejunkman wrote:Joyous wrote: Hello hedz, I have unique mixture twice and still not managing so have taken to my Little store presently for them to kind as still under assurance. I am having concerns discovering an adaptor that fits the non smoking huge I have three but nine fit? Can anyone let me know which kind of adaptor will fit the non smoking huge or offer me a weblink to where I can buy one?![]()
1964 f100
292 yblock
1969 Ranger
Loving all ford vehicles
292 yblock
1969 Ranger
