4wd conversion steering column question.
grabberblue72
Post by grabberblue72 »
Is it possible to swap the steering column shaft in my 72 2wd column with a shaft from my 77 non tilt 4x4 column ?
grabberblue72
Re: 4wd conversion steering column question.
what are guys doing for a steering column when converting 2wd to a 4wd?
71PA_Highboy
Post by 71PA_Highboy »
Flaming River or Borgeson ujoints and intermediate shaft...
Quick and easy and works much better... but $$$$
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
grabberblue72
And they will connect to my 2wd steering Column? Or do I still have to find a dent side 4wd steering column?
71PA_Highboy
they will connect to whatever you want.
You spec the spline count (or D or double flat) and they send you what you need.
Got Ford?
1 Lincoln Mark VIII
BigBlueF250
Post by BigBlueF250 »
I did just what you asked on mine. 77 shaft in 69 column.
grabberblue72
I just finished mine also. It was way easier then I thought it would be.
